exhaust temperature in water jacketed headers >
Old 03-10-2011 | 09:10 AM
Default exhaust temperature in water jacketed headers
Can anyone tell me the nominal temperature or temperature gradient of the exhaust gases at both ends of a water jacketed header on a naturally aspirated gas engine.
Also, please let me know any contributing factors to the exhaust temperature.
any info or pointers are appreciated.
thanks in advance
d1mbu1b is offline
Old 03-10-2011 | 09:53 AM
The water jackets are there not to cool the exhaust gas, but to cool the outer pipes, so they dont get hot like a car does. High exhaust temps can be from a lean fuel mixture, or retarded timing.
MILD THUNDER is offline
Old 03-10-2011 | 12:52 PM
Originally Posted by MILD THUNDER
The water jackets are there not to cool the exhaust gas, but to cool the outer pipes, so they don't get hot like a car does. High exhaust temps can be from a lean fuel mixture, or retarded timing.
Thank you.
Ignition timing or vavle timing?
I am trying to get a rough order on the actual measured temperatures.
I just have no idea what practical exhaust temperatures are and figured the water jacket may be influencing the temperature at the collector and slowing down the slugs and the pulses.
Basically, for argument sake, if a normal auto exhaust is 700 degrees C at the collector would a water jacketed exhaust be closer to 500 or 700?
d1mbu1b is offline
Old 03-10-2011 | 09:41 PM
you should be able to lay your hands on the manifold without getting burned.....
kubelwagonman is offline
Old 03-10-2011 | 11:18 PM
tcelano's Avatar
I think the question is what an egt probe will read. How much lower should an egt measured just after the collector on a CMI header vs an automotive header.
Also, how much heat would be lost between reading an egt right in the runner vs after the collector? Thanks
tcelano is offline
Old 03-11-2011 | 06:21 AM
Exactly, thank you.
How and where do you install an EGT sensor on a jacketed header?
Is there a way you can snake a probe up the exhaust to measure?
d1mbu1b is offline
Old 03-12-2011 | 07:38 AM
PatriYacht's Avatar
I don't think it would be any cooler than car exhaust. You are running under higher loads and throttle openings in a boat. That would more than make up for any cooling from the manifold.
PatriYacht is offline
Old 03-12-2011 | 08:00 AM
on the Dino mine had ~ 1400 farenheit each port !
DareDevil is offline
Old 03-12-2011 | 08:21 AM
I'm running a egt right at the head #7 cylinder I have it tuned to see 700-725 @ idle cruising about 850-950 wot 1350- 1400 @ wot is about 12.5 afr That was how i did a close tune. I did a safe tune on it 2 years ago . I will be tuning with the dual channel lm2 meter this year tuning by a temp will prevent melt downs it is the closest to afr reading for a safe tune.
Rockfish71 is offline
Old 03-16-2011 | 01:34 PM
Thank you. Do you have any advise on purchasing or installing the EGT sender?
d1mbu1b is offline
