Wet sand and wheel?
Old 03-14-2011 | 09:02 PM
Default Wet sand and wheel?
On avarage how many times can you wet sand and wheel out boat?
slpcamaross97 is offline
Old 03-15-2011 | 10:15 AM
glassdave's Avatar
Neno the mind boggler
Till ya see fiberglass
Not sure if there is any rule of thumb here. First make sure the finish is gel and not paint. Some boats, like the 38 ZX i have, have a clear coat on the gel on the sides of the boat but not the deck. If its gel i would imagine as many times as you care to. The gel is going to be the same at all levels, or should be anyway. There could be a point the UV damage is sever enough that sanding and buffing is a waste of time though. At that point the effort put into restoring the surface is about the same as painting it. Hope this helps.
08 OPA High Points Champion
glassdave is offline
Old 03-16-2011 | 08:21 AM
I was kind of wondering this my self, So Dave your saying on any typical Gel Coat finished boat that is great shape I can continue to use a mild cleaner like 3mm Finesse once a season with maybe something a little more aggressive every other season for say the next 10 years with out significantly thinning the gel coat? ….The boat is always racked stored inside when not in use. Thanks……..
johnny b good is offline
Old 03-16-2011 | 08:29 AM
Should gel be wet sanded with block rather than a da
Drock78 is offline
Old 03-16-2011 | 09:33 AM
glassdave's Avatar
Yes that should be fine, gelcoat is pretty durable. In all my experience I've never buffed through, sanded yes but buffed no. Like anything there is a limit though, with paint the margin is very small but gelcoat is generally pretty thick. Biggest issue with gel is gonna be UV damage and that can run pretty deep. If you keep up on it you shouldn't have a problem. My boat is ten years old and still looks almost as new and the gel is nice and bright white. I use Fountain of Youths totally buff once a year and their Quick Shine the rest of the time with Power One on the running surface.
http://www.fountainofyouthrestore.co...outh_Home.html
either works but i use a DA unless i need to straighten something out.
Old 03-16-2011 | 02:18 PM
Default Look close!
Be sure porosity hasnt started to show before any sanding begins
Fiberglass fixr is offline
Old 03-16-2011 | 02:42 PM
Seems to make for a nicer job
Old 03-16-2011 | 03:18 PM
the block does a nicer job?
Drock78 is offline
Old 03-16-2011 | 03:27 PM
scarabman's Avatar
How does that change the equation? What would be the porosity test, or what do you look for?
scarabman is offline
Old 03-16-2011 | 03:32 PM
DA is faster but the Block will give a flater straighter finish
