keith eickert  valve covers  will they fit ??? >
Old 03-15-2011 | 07:00 PM
Default keith eickert valve covers will they fit ???
looking at buying keith eickert 2 piece valve covers .question is will they clear my app .i have dart merlins w a jesel rocker system motor is gm bowti tall deck running gil exhaust .i called cp perf and they said they had some issues w jesels in the past .before i spend grand on cvrs thought id ask . as always THANX
smokin' gun is offline
Old 03-15-2011 | 07:05 PM
They Fit !!!!!!!!
DareDevil is offline
Old 03-15-2011 | 07:06 PM
I run the jesel under mine with no problems I have dart pro 1 heads
dennis r is offline
Old 03-15-2011 | 07:17 PM
They work with bb5's and jesels but they do not clear the blower intakes with out a mode to the intake
here is a pic of the bb5/632 tall decks I will post pics of the blower intake later
Attached Thumbnails keith eickert  valve covers  will they fit ???-winter-pro-132.jpg
lightning jet is offline
Old 03-15-2011 | 08:45 PM
Vinny P's Avatar
I hate the winter!!
One thing I can almost gaurantee is that they will leak. Mine leak no matter what I have tried. The only way to stop mine from leaking is to run a bead of silicone around them before locking them down. The bad thing about that is you need dynamite to get them back off. So much for easy 2 bolt removing of the covers.
Vinny P is offline
Old 03-15-2011 | 08:56 PM
I believe the only ones that leaked were a bad run years ago that were produced by one of the buyers of Keith's business. This was before Hardin bought the company. Before you order from CP/Hardin/KEPP you might price the real Keith Eickert newest 2 pc VC system. They are OSO advertisers, Lightning Performance Group 386 793 6158. They appear to take this already nice product to the next level.
Ben
BenPerfected is offline
Old 03-15-2011 | 10:00 PM
No leaks here they work just fine 2c
Old 03-16-2011 | 12:34 AM
I have been using them for years with both stud mounted rockers and Jesel and T and D shaft rockers. I've put the on Dart's, Brodix, AFR's, etc. However, I have also had them leak.
I mill a groove in the base rail to help the oil drain from the rail. They have now come out with a rubber gasket that sits in the base. The cover sits down on top of it and should seal it up permenantly. I don't know if it can be put on older ones. I'm not sure if they are milling the base differently to accept the gasket. I will take some pics tomorrow of the gasket.
Eddie
Young Performance is offline
Old 03-16-2011 | 04:21 AM
I have Jesels on mine as well. And mine also leak.
I usually just run some RTV silicone around them, messy but it stops the leak. I never thought about putting a gasket on the bottom, I may make one up and try it out this season.
Philm is offline
Old 03-16-2011 | 08:12 AM
Check these out....
http://www.offshoreonly.com/forums/o...lve-cover.html
