Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
How do you tell if its paint or gel? >
Old 03-16-2011 | 03:03 PM
Default How do you tell if its paint or gel?
Title kinda sums it up..
Just wondering if what I have is paint or gel before I start researching polishing techniques..
waterboy222 is offline
Old 03-18-2011 | 06:31 AM
If the surface is very smooth you most likely have gel coat. Paint will leave a bit of an edge where it was taped off.
08 fastech 292 is offline
Old 03-18-2011 | 07:24 AM
not if it was cleared over , she'll be smooth as a babys bottum ..Cale all them EDock boyz up there and none can eyeball and tell the diff ???
Old 03-18-2011 | 08:52 AM
Regardless of the finish the polishing tecniques are similar. The condition of the finish will determine the necessary steps required to achieve optimal results.
RBeyer is offline
Old 03-18-2011 | 07:16 PM
Velocity Vector's Avatar
Crazy Energy
Use a paint thickness meter, any good body shop should be able to help you without having to buy one.
Velocity Vector is offline
Old 03-22-2011 | 08:40 PM
whats better paint or gel
seaman is offline
