What fuel pump for 1400 hp
thanks Eddie, but damn one of these days I've got to get you converted to the "right" regualtor..............the 2345-A would be the best bet if 1400+ with a blower.
Use a regulator that is matched to the flow of the pump so it can control the pressure at idle. If you are seeing 1400 hp on the dyno the Procharger is using another 200 or so.
I sure was glad to get those 1100A's from you. They performed flawlessly as usual. Made 1100 hp with no issues. They were able to hold 56 psi with ease.
Talk soon.
Eddie
