What fuel:oil ratio after removing oil injection?
My Promax 300's have had the oil tank and injection setup blocked off to avoid the gear failure problems.. The previous owner told me he runs 50:1 but to me that seems kinda light on oil..
I sure dont want to run it to light on oil..
I know the oil debate has been beaten into the ground, but all the threads on it are now 4 or 5 years old.. What oil would you recommend?
Merc reccomends running the 2.5L's at 40-1 with Merc High perf oil. I run Klotz R50 at 40-1 pre-mix never had a lubrication failure. But we are turing 9000rpm+ . I would feel a litte safer at 40-1.
Jeff
Jeff
There are some variables you need to consider. If the motors are EFI (I don't think Merc made the Pro Max in a carb model), stock except for the oil injection mods and you will not be running at WOT all the time then 50:1 will be fine.
If the rev limiters have been removed with an aftermarket chip and/or you like to run hard I would recommend 40:1 with a good synthetic like Klotz, Royal Purple, Amsoil etc.. the extra lubrication will help with engine life.
John
John
http://www.amsoil.com/storefront/ato.aspx
Even at 100:1, its still 3-4 times stronger than any other 50:1 mix out there!
