Weight on 3 axle trailer
Old 03-20-2011 | 10:26 AM
Default Weight on 3 axle trailer
Generally whats a trailer like this weight?
Boat is 7500# empty, trying to figure out what it will be all together.
ICDEDPPL is offline
Old 03-20-2011 | 12:05 PM
seafordguy's Avatar
Steel or aluminum??
seafordguy is offline
Old 03-20-2011 | 12:36 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Not sure if correct, but the sticker on my Eagle shows a GVWT of 10500#, and a load carryng cap of 8750#.
I'd assume the 1750# difference would be the trailer weight.
US1 Fountain is offline
Old 03-20-2011 | 01:35 PM
Underdog88's Avatar
Veteran: Navy
My steel Eagle is for a 30ft boat and is 1800lbs.
Underdog88 is offline
Old 03-20-2011 | 08:52 PM
My 33 AT is on a dual axle aluminum Manning with tool box as yours and weighs #2260. With another axle (albeit smaller) and I'm guessing that Eagle is a steel trailer I'ld think #2700.
Steve
509 SC is offline
Old 03-20-2011 | 09:00 PM
i say 1800-2200 pounds for that eagle steel trailer.
mine is steel Myco twin axle and is 38 total length and weighs 2200 # !
DareDevil is offline
Old 03-22-2011 | 08:03 AM
Underdog88's Avatar
Veteran: Navy
Says 1800 on the Man Cert of Org and Title... shrug
Old 03-22-2011 | 10:08 PM
Try putting it on a Cat scale, you might be surprised!
509 SC is offline
Old 03-23-2011 | 09:20 AM
I thought it would be around 2,500-3,000
I have a dump trailer two axle, 6x12 nothing crazy and that thing is 2, 500lbs
ICDEDPPL is offline
Old 03-23-2011 | 09:52 AM
Probably boat, trailer, fuel, gear in boat, i'd imagine your gonna be pulling 11-12k behind you. My old Formula 402 Was about 16,500 on a steel trailer, 1/8th tanks of fuel.
My old single engine 24FT Four winns Liberator was about 7400lbs on a steel trailer.
Stop at a truck stop and use their cat scale. Its pretty cool to find out what your rig really weighs. You can weigh the truck and trailer, then go drop the trailer, and weigh just the truck. Then subtract.
MILD THUNDER is offline
