Hynautic Helm Pump
Old 03-21-2011 | 09:20 PM
Rookie's Avatar
Default Hynautic Helm Pump
Hynautic H-21 helm pump.
$150/offer
http://www.go2marine.com/product.do?no=81264F
Rookie is offline
Old 03-22-2011 | 08:55 AM
Would this be for a single ram (single engine) or twins? What would be required in addition to this helm pump to convert a boat that has "hynautic" (cable to transom, then hydraulic assist) to full hydraulic?
dba900 is offline
Old 03-22-2011 | 09:50 AM
Rookie's Avatar
You would need external rams, Pressure Reservoir, relief valve or a Hynautic Reservalve that combines both. You can find them on ebay or I have seen a couple in the OSO swap.
http://teleflex.ru/upload/files/cata...d-Hynautic.pdf
Rookie is offline
Old 03-22-2011 | 10:05 AM
So if the boat already has external rams fed by the power steering pump, would you eliminate the power steering pump in a full hydraulic system? In other words, you turn the drives by hydraulic pressure without using a mechanical pump to assist you?
Sorry for the dumb questions.
dba900 is offline
Old 03-22-2011 | 10:46 AM
Rookie's Avatar
No dumb questions. The helm is an actual displacement pump (I think it is ~1000PSI). You disconnect your steering pump and cylinder from the back and plumb directly to the cylinder with the Reservalve in place. These are used more in outboard application then I/O cause they lack the power steering pump. I did have it on my I/O though.
Rookie is offline
Old 03-24-2011 | 06:43 AM
Rookie's Avatar
Ttt
Rookie is offline
Old 03-26-2011 | 11:35 AM
Rookie's Avatar
TTT
offers?
Rookie is offline
Old 12-21-2011 | 03:49 PM
is the h-21 pump still available from rookie? Thks!
sailorsmile is offline
Old 12-21-2011 | 06:03 PM
Rookie's Avatar
Yes, pretty sure it is still sitting out at my shop.
Rookie is offline
