Will stock Merc/GM windage tray clear stroker crank? >
Old 03-23-2011 | 02:51 PM
Default Will stock Merc/GM windage tray clear stroker crank?
Will the stock GM windage tray (PN 3967854) work with a 4.25 stroker crank? I'm looking for some guys who have built 540's or 496's to chime in here to let me know if I will have clearance issues before I order a tray and the stud kit to mount it.
BTW, those studs must be made of a gold/unobtanium alloy. None of the GM dealers in my area stocks them, and they want close to $20 EACH for the danged things.
Confusion - the tray literature says to use PN 3902885 studs to mount the tray, but there is also a PN 10224104 that is listed as a windage tray main stud that sells for $7.50 each. Does anyone know the difference? Better yet, does anyone have an old windage tray and studs laying around that they want to unload cheap?
Thanks!
Budman II is offline
Old 03-23-2011 | 03:08 PM
t500hps's Avatar
21 and 42 footers
My 500EFI's were turned into 540's and we re-used the stock windage trays........that was 4 years ago and the motors still run fine, without hitting the trays.
t500hps is offline
Old 03-23-2011 | 03:37 PM
Thanks T500 - wish I could find one used. The tray is priced reasonably, but $17 a pop for a stud is hard to take.
Old 03-23-2011 | 07:20 PM
which stud kit you looking for. If you are looking for ARP 235-5606, I have 2 new sets that I will let go cheap.
Allen
29scarab10 is offline
Old 03-23-2011 | 08:04 PM
My Mark IV 496 stroker uses the stock try
f_inscreenname is offline
Old 03-24-2011 | 07:51 AM
my gen 5 454/496 uses the stock one also
SED70 is offline
Old 03-24-2011 | 07:59 AM
Thanks for the answers, guys. Now I just need to determine if I can use the 10224104 main studs (listed as "Windage Tray Stud, Gen V 454 & 502") that sells for $7.50, or if I need to use the other part number (3902885) that sells for twice as much. I'm sure the more expensive one will be the one that I need!
