Bravo shift cable bellow
Time to replace all seals. Is it possible to replace the shift cable bellow without removing/replacing the shift cable? Cables are fine but strapped down every 10 inches inside the boat which would make replacement difficult without pulling motors. Has anybody had success with replacing the bellow w/out removing the shift cable?
If I remember right you can't get the boot off that end of the shift cable because it has the nut part that bolts the cable assembly to the bell housing. The cable installs from the outside to inside the boat. If you disconnect it on the inside and tie a pull string to it. Pull it out from behind the boat and hook the new cable on to your pull string, and then pull the new cable back into the boat. Had to do one in LOTO a couple of years ago due to a broken shift cable in the drive side.
Point #1 the cable end on the inside goes in first. So the cable needs to come all the way out. You might get by leaving the cable in place on the bellhousing, but it's a pain.
Point # 2 All those zip ties holding the cable down are a no no. The shift cable needs to free float.
Mac.
Mac.
