How can I clean up superchagers??? >
Old 03-27-2011 | 05:58 AM
Default How can I clean up superchagers???
any one have suggestions Im thinking beadblast or wire brush then hand polish or brakekleen any help before I mess them up thanx Tommy
tommyvt59 is offline
Old 03-27-2011 | 07:27 AM
Try wet sanding it then buff with some rouge. Go to eastwood.com
TURBO JET is offline
Old 03-27-2011 | 11:51 AM
lucky strike's Avatar
Never Dull
lucky strike is offline
Old 03-27-2011 | 12:20 PM
That super charger was never a polished version and that is pretty much the way it will look unless you have it completely polished out.
Griff is offline
Old 03-27-2011 | 01:18 PM
Coolerman's Avatar
PF Marine
What type of "clean up" are you looking for? If you want a light polish, here are a few steps. It'd probably take 4hrs or so.
-Sisal wheel (sharp cut wheel) and a 240/300 greasless compound
-Sisal Wheel and a sharp cut compound.
-Spiral sewn wheel (med cut wheel) with tripoli compound (med cut compound)
-Loose wheel (not sewn, finishing cut) with soft cut compound.
There is also a recommended RMP that you spin the wheels at. My personal preference is to spin them a bit faster and use a little less pressure if you are using your buffs in a 6" grinder. You have to make sure not to let the wheel catch on anything though.
Also, a wire wheel will put some scratches in the surface that are a pain to take out in later finishing steps of the polish.
Beware, it is not a fun process!
Here is a pic of an intercooler I just polished using a little more in depth process.
Attached Thumbnails How can I clean up superchagers???-finished-47-posting.jpg
Coolerman is offline
Old 03-27-2011 | 01:35 PM
Yeah, take it to Coolerman......
ozarkdevil is offline
Old 03-27-2011 | 01:41 PM
Coolerman's Avatar
PF Marine
Ha, polishing shops make me really nervous......
Old 03-27-2011 | 01:43 PM
There is also a recommended RMP that you spin the wheels at. My personal preference is to spin them a bit faster and use a little pressure if you using your buffs in a 6" grinder. You have to make sure not to let the wheel catch on anything though.
WOW thats what im looking for looks sweet!!!!
Old 03-27-2011 | 03:04 PM
+1 there
Whatever you do, don't take a wire wheel to it, you won't be happy.
wjb21ndtown is offline
Old 03-27-2011 | 03:16 PM
u need to stop by the shop , i have some polishing waiting for you since your so good at it .
