230 hp bigger rocker arms? >
Old 03-28-2011 | 12:25 PM
Default 230 hp bigger rocker arms?
I have a Chris Craft 230 Scorpion Limited. I have a set of World Products torquer heads and a Performer intake. I know the RPM performer would be ideal but this is what I have for now. Would there be a noticable increase from going with 1.6 rockers instead of 1.5's? Don't want to do the cam just yet.
Thanks.
CC230 is offline
Old 03-28-2011 | 01:17 PM
From what I've been reading on other forums I don't think it would be worth it for now.
CC230 is offline
Old 03-28-2011 | 01:33 PM
You may not have enough motor to take advantage of the extra lift. What size motor, carb and cam specs are needed to make a guess that has any value.
ThisIsLivin is offline
Old 03-29-2011 | 06:02 AM
Sorry, stock 260hp. It has a cracked head. Runs fine the crack is on the outside between the exhaust ports. These World heads were given to me, so I'll replace them for now and do a rebuild in a few years. The motor has 500 hrs on it.
Thanks.
CC230 is offline
Old 03-30-2011 | 09:26 PM
I would get some Vortec heads. skip the rockers because you wont want them when you do get a real cam.
Roller rockers would be better than 1.6's, because you can use them down the road
rexcramer1 is offline
Old 04-04-2011 | 02:00 PM
The world products Torquers are what I run on a 406 i'm building third go around they work good with gasket match and pocket port, and have pretty thick deck surfaces, also raised valve cover rails. I run roller rockers with standard ht covers no issues, also have induction hardened seats, just my 2cts
doggiedave is offline
Old 04-04-2011 | 02:01 PM
P.S. also come with screw in studs
