Comparing Lifts
Old 03-28-2011 | 02:21 PM
Default Comparing Lifts
I'm planning on having a boat house built later this year and I'm in the process of comparing boat lifts. I'm planning on lifting a Fountain 38EC. Water is brackish. So far the companies I've looked at are: Hi-Tide, Tide-Tammer, and Boat Lift U.S., and I'm leaning towards Hi-Tide mainly because of the longer warranty. But I have zero experience with lifts so I'd be interested in hearing any good or bad experiences any of you have had with your lift.
Thanks,
SR-71
SR-71 is offline
Old 03-28-2011 | 02:57 PM
I think you may be in the right direction. I would stay away for a sling with straps that hoists your boat in the air. They can warp the boat. I have seen a 38 foot Scarab that was warped in the top/front of the boat because it was suspened with straps. It looked like a bubble and it was uneven. As long as the lift has support like it was sitting on a boat trailer, you should be OK.
UrbanDisturbance is offline
Old 03-28-2011 | 04:08 PM
Ummm...why is this in this section ?
tinman565 is offline
Old 03-28-2011 | 05:41 PM
Default Fixx
probably because the lifts and trailers and in the same for-sale section
FIXX is offline
Old 03-29-2011 | 08:00 AM
Karaokemike's Avatar
I use to sell and install Hi Tide Lifts. You will be the happiest with them. The only thing I would recomend is that when you buld the boat house put seperate pilings in for the lift. They do have boat house brackets but I do not think the provide the support that a piling does. The lifts are quite, fast and have a better look. If there is anything I can do to help please let me know.
Karaokemike is offline
Old 03-29-2011 | 08:09 AM
offshoredrillin's Avatar
I like these, that way when the boat is up , you can walk around it and clean it or work on it. inside a boat house you would basically have a floor that raises.
http://www.noprofileboatlifts.com/
offshoredrillin is offline
Old 03-29-2011 | 08:40 AM
Those are pretty cool.
Old 03-29-2011 | 08:46 AM
A. Transportation (in this case... vertical transportation).
B. I couldn't find a better place to post this thread.
SR-71
SR-71 is offline
