Anyone know the factory torque spec for a 500 EFI rod bearing?
73 for the H beams. And ARP says if they are stretched more than .001" unloaded they should not be re-used. If you use a bolt stretch gauge they are supposed to stretch .005" when torqued. Make sure you grease the threads and heads before torquing.
