Where to buy non skid for integrated swim platforms.
I have a 94 272 and was wondering where I can buy replacement material or exact replacement non skid pieces that are on the swim platform. The 4 non slip sections.
my 2 cents - get the 3m backing pre-installed on it so you dont have to mess with glue. However, take your time removing the old stuff - its a serious pain in the arse but well worth it in the long run. get a pack of razor blades ready to scrape it bit by bit in order to get all the nasty off the platform.
I agree, get the 3m backing pre-installed on it so you dont have to mess with glue. Once I removed the old stuff I used Goof Off to get the nasty glue residue off.
I contacted them and had them send me samples of 3-4 colors that I thought would look good and different patterns, then I chose what I liked best. Made a template and cut it out with a razor knife.
Make sure your pattern is a thick/stiff material so you do not get any flex when tracing it out.
My Donzi 35 ZR was a total hazzard. After two cases of nearly big injuries, I went with No Skidding (www.noskidding.com) Lots of colors and styles to pick from, and excellent customer service.
Just did our 272 with hydroturf, used the purple w cut grooves. Turned out really nice. Peeled the old stuff off and used adhesive remover on the goo. Will try to get a pic posted.
