Gelcoat
Old 03-30-2011 | 11:01 AM
Default Gelcoat
I was wondering if anyone knows a source for getting gelcoat color matched in small quantities, like a pint. I called Spectrum and they said there minimum quantity for a color match is 1 gallon. The boat is a red 2000 Baja. Thanks
40j4a is offline
Old 03-30-2011 | 11:39 AM
Try Minicraft. They are in Florida. Good luck.
427 larry is offline
Old 03-30-2011 | 11:53 AM
427 thanks I'll give them a call.
40j4a is offline
Old 04-01-2011 | 09:58 AM
May try Spectrum again, I've always used them for color matched gel and always get it by the quart. Never asked about a pint though.
Brandon is offline
Old 04-10-2011 | 12:26 AM
You can get a quart and ask them to keep the rest. Saves on shipping as for mini craft. Only last resort there.
Bottoms Up is offline
Old 04-14-2011 | 07:58 PM
Well I've checked with both Mini-craft and Spectrum and both can color match to a piece of gel coated glass that I cut out for a speaker installation. Mini-craft has a mininum of one quart and Spectrum requires a 1 gal. min.. Spectrum does have quarts in the original Baja red, but I'm not sure how well it will match because of the age of the boat. Its a 2000 and while its looks great I'm sure the color has changed over the years. So I'm not sure which route I'll take, but I think Mini-craft might be a better choice because of the color matching.
40j4a is offline
Old 04-14-2011 | 08:38 PM
Default Fixx
Try ferro! 574-935-5131
FIXX is offline
Old 04-15-2011 | 02:54 PM
Knot 4 Me's Avatar
Are you spraying or doing small nick/gouge repairs? If you are spraying just get white and have a local shop tint it for you. Depending on the boat's age the local match will probably be closer in color.
Knot 4 Me is offline
Old 04-19-2011 | 08:15 PM
I talked to Michigan Fiberglass and they will color match my sample in any quanity, so I'm going to give them a try. Thanks for everyones help I appreciate it.....
40j4a is offline
