Through hull water pick up epoxy >
Old 03-30-2011 | 05:40 PM
Default Through hull water pick up epoxy
What kind of epoxy to install a through hull water pick up
dennis r is offline
Old 03-31-2011 | 01:07 AM
Seal it with 3m brand 5200
speedreeder is offline
Old 03-31-2011 | 01:25 AM
X2
Griff is offline
Old 03-31-2011 | 02:16 PM
Fountain4402's Avatar
they have it at west marine probably the 3m stuff they are talking about above. Not cheap stuff though
Fountain4402 is offline
Old 03-31-2011 | 02:28 PM
I would seal the hole first with epoxy to prevent moisture from getting into the glass or coring. Then when you install the stainless fitting you can use 5200. As I'm thinking about this, if you are planning on going fast the water may erode the 5200 maybe it would be better to completely epoxy in the fitting.
kvogt is offline
Old 03-31-2011 | 04:03 PM
We have had this done and it should be pretty straight forward. My suggestion is to post on the Paint and Fiberglass forum and ask GlassDave for his input on the right resins/materials for the job. Are you using the Stainless Marine thru hull pick-up's?
BenPerfected is offline
Old 03-31-2011 | 04:22 PM
West systems 105/207 resin & hardner
