Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Through hull water pickup epoxy >
Old 03-31-2011 | 04:28 PM
Default Through hull water pickup epoxy
What should I use for my through hull fitting for my water pickup. It is for my intercooler.
dennis r is offline
Old 03-31-2011 | 04:34 PM
glassdave's Avatar
Neno the mind boggler
generally use 3M's 5200 unless its a molded in or recessed laminar flow type. what kind of pickup are you using? Does it go through the running surface or up the transom then in?
08 OPA High Points Champion
glassdave is offline
Old 03-31-2011 | 06:39 PM
It goes through the running surface of the boat. It is just a tube that goes through and you cut it off at the bottom with the contour of the boat with a little scoop in the trailing edge
dennis r is offline
Old 03-31-2011 | 10:21 PM
glassdave's Avatar
we have those on the race boat. We used a mix of west system epoxy and their 404 high density adheasive filler and added a touch of coarse milled fiber.
