Bravo Upper Drive trim guide crack repair >
Old 03-31-2011 | 09:50 PM
Question Bravo Upper Drive trim guide crack repair
The tab is cracked on my Bravo upper lower unit, the tab that rubs againts the gimbal when trimming.
This was caused by a steering malfunction (not from wear and tear)
Can that be welded?
My understanding, if properly done, it can be welded stronger than the original design.
How much torque is on that?
2Slow4me is offline
Old 04-01-2011 | 12:29 AM
Found this, I think this with the weld, would be better than new!
http://www.lathammarine.com/bravo-br...nforcement.htm
2Slow4me is offline
Old 04-01-2011 | 06:06 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I machined a couple of blocks like those for a buddy who's broke at the same place to reinforce the load there. Makes it 1 solid area. As far as I know they are doing the trick.
US1 Fountain is offline
Old 04-01-2011 | 08:38 AM
Thanks for letting me know, I appreciate it.
How big are those blocks?
And I assume aluminum?
Since I'm having mine welded at the same time, I'll get them to make something up like you did.
Anything that I should point out that there should be clearance for? (Probably obvious when on the gimbal, but not when apart)
P.S. Any chance you have a pic of the block?
2Slow4me is offline
Old 04-01-2011 | 08:55 AM
Max Machine also has the block.
http://maxmachineworx.com/accTrimBlock.htm
BenPerfected is offline
Old 04-01-2011 | 10:00 AM
Thanks!
Big price difference as well. WORX $95.oo Latham $282.51
Greatly appreciated, thanks again!
2Slow4me is offline
Old 04-01-2011 | 11:31 AM
Just found out, this one does not fit pre-2000 drives for some reason
2Slow4me is offline
Old 04-01-2011 | 11:37 AM
http://www.jrmarine.com/ all you need Bro
Old 04-03-2011 | 09:52 PM
Ginger or Mary Ann?
They were a copy of the Max Marine ones, no pics. Yes, Aluminum.
