Salt Water
Old 05-23-2002 | 06:43 PM
Steamin Rice's Avatar
Default Salt Water
I'm new to boating in Salt Water and want to get some tips for keeping the boat maintained while using it in salt water. I know about flushing the motor and rinsing the trailer off with fresh water and keeping the boat clean. What else should I be doing?
Steamin Rice is offline
Old 05-23-2002 | 08:34 PM
cuda's Avatar
One thing you want to remember is to spray is down twice with fresh water. The first spraying puts the salt in solution, then the second rinses it off. If you don't use salt away, I put some dishwashing liquid in the flush hose before I hook it up. Not sure if it helps any, but it makes me feel better, and also I know when I quit seeing bubbles, it has flushed completely through the engine. Remember, rust never sleeps!
cuda is offline
Old 05-23-2002 | 11:54 PM
Tonto's Avatar
Like Fever Mike said...Salt Away,Salt Away,Salt Away. Flush the engine, rinse the boat, and rinse the engine itself with the stuff. Then I spay EVERYTHING with CRC to keep the rust down. If you do get any rust stains on the boat, i.e. bow eye, transom rings, cleats, etc. you can use ON-OFF hull cleaner to remove them. Be careful with the ON-OFF though as it is full of acid and will burn your eyes make you cough etc. Keep the boat waxed also, as everyone else said.
Robert
Tonto is offline
Old 05-24-2002 | 12:40 PM
Thanks for the tips...Sounds like I need to get my hands on some Salt-Away.....
boatnt
03-19-2006 04:37 PM
jeff32
01-09-2006 07:21 AM
Stormrider
03-04-2005 09:29 PM
vanderheyden
4
11-19-2003 06:30 PM
flylevel
07-18-2002 11:43 PM
