Best f350 4x4 tires sizes
Right now I have a 4x4 f350, crew cab, The tires are
35x12.50x18,Pro Comps, when Im turning they rub, I like the taller look the tires give, what size would be the best to stop the rubbing and keep the aggressive look?
add a 2" lift in the front only. That will level the front and rear to be the same. The tires will not rub. My 11's came with 275 65 r20's..I changed the F350 to 325 60 r20, kept the factory rim.. with a 2" lift and they rub just the slightest when turning cranked all the way left....
