Entry level power boat??
I'm looking into buying a powerboat for the first time and I'm wanting to know some things to look for and things to stay away from..boats, motors and outdrives..I have owned high performance bass boats ,bay boats but new to this...I'm looking for boats 25' to 30'...Thanks for any words of advice...
Stock power for reliability, buy the biggest motor you can afford that was offered for the boat.
There are a ton of great boats in that range,,,post some here you start looking at and you will get a bunch or reviews and opinions.
Ill start,,,very late 90's to early 2000's ( depending on yhour budget ) baja 272 with a 502.
Alot of room, great ride for the size and affordable.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
I'm guessing around 4-6 people..mostly on lakes..But I'm not far from the coast though..My budget is in the $30'S..I have found some boats with wipple chargers???I have done some research and the 496HO seams to be the engine to get.Thanks for any and all help....
There's soo many makes/models out there in the 25-30 range, you could look for a long time.... Just be cautious when buying a used boat,,, and normally the older the boat is,, the chances of there being problems later is highly increased....
Normally you get what you pay for.....
If your on a budget,,, and aren't looking to have to engine troubles , I would stay away from anything whipple charged, superchargered..etc... Stock, turn-key , reliable power is always nice.... See if you perfer a Cat or Vee, and Good Luck!
The 496 is great if you will be happy with stock, but moist people are not. If you are more the type to change boats rather than add on an existing boat, than start with a 496HO mag.
But remember, where you start is where you will end without major bucks. A 454 can be built to make lots of hp for a reasonable amount of money.
If you can get one in your price range, get a twin engine boat. If you get much bigger than 25/26 on one engine, you will be SLOW. Of course it goes without saying, you must buy a cat or you will be SLOW.
Good Luck!
