engine compartment
Old 04-03-2011 | 09:14 AM
Default engine compartment
Does anyone have an idea what is the quickest and most effective way to clean the area underneath the engines.My motors are out and I want to clean 20 years of grime off the bottom.Any answers would be appreciated.Thanks
davej is offline
Old 04-03-2011 | 10:05 AM
I used Simple Green, full strength, sprayed it directly, used a plastic bristle brush to work it through the crud. A little bit of water helps, but not so much to dilute the simple green. Took about 2 hours of scrubbing and rinsing
bustedbrick is offline
Old 04-03-2011 | 10:46 AM
Thanks for your time,do you think any over spray will damage electrical wires,etc.?
davej is offline
Old 04-03-2011 | 08:01 PM
Rookie's Avatar
I just did mine which was a mess, 25 years of grime. At work when we move a press which leaks years of hydraulic oil on to the floor we found out the best cleaner to clean the floor for paint is a can of Comet powdered cleanser. $1 at the dollar store. I used a hand scrub brush and a new round toilet bowl brush to get in to crevices. I scrubbed for about 2 hours and hose it out the drain plug into a 5 gallon bucket. After drying over night I then used rags and wiped down the bilge 4 to 5 times with isopropyl alcohol to get the last of the residue of and ready for paint. You will be surprised at how good isopropyl cuts grease. I then painted.
It was a lot of work
Attached Thumbnails engine compartment-bilge.jpg   engine compartment-bilge1.jpg
Rookie is offline
Old 04-03-2011 | 08:10 PM
Nope, it's pretty mild. Rinse well anyways.
Dang Rookie that looks great!
Old 04-03-2011 | 09:56 PM
I have a product called Bio-Clean.It works awesome on bilges and its also a fire retardant.Go to Adrenalinerushracing.com and click on the Power1One logo.you can order it there and I will send it right to your house or business.Its made by Fountain of Youth restoration products.They sponsor my race boat.Thanks
heater63 is offline
Old 04-04-2011 | 02:25 PM
carter38's Avatar
I use castrol super clean and a good brush and dig in/
carter38 is offline
Old 04-10-2011 | 07:12 PM
Lacquer thinners......lots of rags.....ventilate well.....Bilge Kote.
Attached Thumbnails engine compartment-dsc00889.jpg   engine compartment-cakes-001.jpg   engine compartment-cakes-002.jpg
pullmytrigger is offline
