525 Impeller housing
Old 04-03-2011 | 09:36 AM
Default 525 Impeller housing
I've researched this and when it's time to change the impeller members are saying to buy the kit not just the impeller, why?
bert4332 is offline
Old 04-03-2011 | 09:44 AM
The housing is cheap, and it gets a groove cut in it from the impeller costing you water pressure.
redbud35 is offline
Old 04-03-2011 | 11:02 AM
Cp Has A Stainless Kit Pretty Cool
schnydo is offline
Old 04-03-2011 | 11:15 AM
dont forget about the 4oz of drive oil that goes in the seapump for the fuel pump,,
TWIN-SPINS is offline
Old 04-03-2011 | 11:30 AM
I put the CP stainless one on mine. I don't know why Mercury would use that cheap plastic housing on a "racing" engine! http://www.donzi.net/forums/showpost...6&postcount=38
thirdchildhood is offline
Old 04-03-2011 | 06:55 PM
Hmmm, where exactly does it go, is it marked? This is a for a 2004
bert4332 is offline
Old 04-03-2011 | 08:50 PM
What's the best way to get the pulley off the seawater pump and press the new one on? Thanks.
sea2jet is offline
Old 04-03-2011 | 09:35 PM
Oil should trickle out this hole with pump installed.
This is to r&r the pulley hub. The pulley itself should come right off. If not I'd pry it off with wood.
When you press on the new pulley make sure you support the other end of the shaft and it says to make sure you get it back in the exact position.
