Spark Plug Question
MR43T need a replacement that is readily available at
autoparts stores, no junk please
I ve heard rapid fire #1 and nkg yr5 ngk is not that easy to find
ac is
ac is
If you just need something to get you going this weekend local auto parts stores will probably have auto version R43T plugs in stock. Same heat range and will work fine in your motor for short term use. They may begin to rust after a while. Nearly all marinas should have the MR43T's in stock.
