Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Painting: floor, gunnels, and interior sides. >
Old 04-06-2011 | 02:15 PM
Default Painting: floor, gunnels, and interior sides.
Hey guys I just finished up replacing the stringers, bulkheads, deck, and gunnels in my 1979 Formula 233ls. Now its the exciting part and time to put some paint down. I have a few questions as far as the finishing of the bare fiberglass.
1. Is it okay to use final fair to even out some spots where the glass didn't lay down perfectly?
2.Should I prime the floor, gunnels, and interior walls with some type of high build primer to even it all out?
3. Still trying to decide on what type of paint for the above mentioned parts. For the floor, I'm thinking either interlux inter-lock, or kwiki-grip. Not sure about the gunnels and walls though.
Any thoughts would be appreciated as to these questions or anything else I should be doing at this stage in the restoration. I will probably be brushing this, but could spray it.....just have to learn how.
bigmike253 is offline
Old 04-07-2011 | 11:41 PM
I would base coat it with gel and then spray a gel coat duratec mixture that will let it shone like paint.
Bottoms Up is offline
Old 04-10-2011 | 03:06 PM
Need a few suggestions for products please. What's a good fairing compound that is hard enough to use on the floor to even up some spots? What are your recomendations for a gel coat? Is evercoat any good?
Old 04-10-2011 | 09:25 PM
Spectrum color.com will have everything you need. There are cheaper but this is the best stuff. They have fairings compound gel coat to roll on first a couple coats then in 24 hours put a last coat on with 50% gel and 50% duratec clear additive and harden normal. Roll or spray in a final coat with this and will shine like paint. The duratec website will have all the info u need.
Old 04-11-2011 | 02:01 PM
Any products from evercoat, interlux, or awlgrip? I get a pretty hefty discount on those or anything from fisheriessupply.com.
Old 04-12-2011 | 10:25 AM
Does anyone have a good write up or know where to find one of how to gel-coat a floor. It seems pretty straight forward but I'm lost as far as the last coat. How do you apply the wax so the gel-coat doesn't cure tacky?
Old 04-12-2011 | 10:35 PM
Default Fixx
as stated,,you wont need wax if you mix the gel with duratec clear 1 to 1 mix..it will dry tack free and shine like paint..Remember what ever the base looks like will look the same finished,if its ruff around the edges the final result will look the same.
FIXX is offline
Old 04-13-2011 | 07:20 AM
+ 1
