ECM Data Gateway and the Garmin GPSMAP® touch screen displays
Data Gateway
SHORT VERSION
The new Livorsi engine ECM Data Gateway brings CAN bus engine data to your existing NMEA 2000® navigation device. It displays the same data that your engine builder or tuner can pull up on their laptops using advanced software. Livorsi’s Data Gateway will interface either by the CAN+ / CAN- wires or by using the diagnostic port on your engine. This device is available for J1939, MEFI4A, MEFI4B, MEFI5, MEFI6. For more info email [email protected]
Data Gateway
With the new engine ECM (Engine Control Module) Data Gateway you can bring CAN (Controller Area Network) bus engine data to an existing NMEA 2000® navigation device. The engine info that displays is the same data that your engine builder or tuner can pull up on their laptops using advanced software. Livorsi’s Data Gateway simply plugs into your navigation unit between the display and the GPS antenna using a standard NMEA 2000® T connector. On the engine side it will interface either by the CAN+ / CAN- wires or by using the diagnostic port on your engine. This device is available for J1939, MEFI4A, MEFI4B, MEFI5, MEFI6.
The Data Gateway will convert your navigation screen into a digital dash board displaying real time engine data and fault codes. One gateway is needed per engine. Livorsi’s optional rigging kit includes a power cord and tee fittings to connect the Data Gateway to your instrument network. Not sure if you nav unit is NMEA 2000® compatible? Email us your make and model number to find out. [email protected]
For complete information at your finger tips, combine the Data Gateway with Livorsi gauges and a Garmin GPSMAP® touch-screen display
Garmin GPSMAP® Displays
Livorsi offers the rugged Garmin GPSMAP® 740, a 7” touch screen unit, that when combined with the Data Gateway, transforms the navigation screen into a digital dash. View real time Data and fault codes; and with the help of user programmable warnings, you’ll be alerted of any potential issues before they become serious problems. The high resolution touch screen lets you navigate the Garmin interface with minimal effort. Garmin touch screens also available in 8” and 12” units. Decorative powder coat bezels available for all three sizes.
Vantage View are digital CAN gauges capable of displaying data for MEFI, SAE J1939, Indmar, NMEA 2000® and Smartcraft® compatible engines. The Mega and Race Series are precision analog gauges featuring bold graphics and stylish rims. Plug-in Deutch connectors make Livorsi gauge installation quick and painless.
