Silent Choice/capt. call exhaust off of 502 MPIs
Everything you need to add captain's call exhaust to your twin set up. If you are getting hastled around the docks about the noise of your boat this is what you need. Everything there to make a twin set up work. I just took it off of my set up and it worked before I dismantled it. Pump looks a little rough but it works good. If you look this stuff up new it is well over $7000 worth of parts from merc. I had to cut the air hose in one spot so you will have to get new hose or make this one work. Plus exhaust tips with internal and external flappers. (I would replace the internal rubber but they are still there). $2500 for the lot and you pay for the packaging and ride. Will seperate tips if not needed but want to sell the pipes together as a package.
Thanks,
Wade
Thanks,
Wade
