bolster seat loose. please help.
Good Morning Guys,
OCD comes out of hibernation next weekend.. Still have snow on the ground and ice on the lake but after this week of 70 degree weather I should be good to go.
On my list of many things to do this year is to fix my captains bolster seat.
The screws keep loosening up. We are sure the holes are stripped. I fear the longer I go without fixing it, it will just get much worse and be harder to fix.
My question to you is:
Has anyone had this problem? How did you fix it?
I have been told to remove the bolster seat, drill out the suspect holes and fill them in? Is this correct?
Also what do I fill it in with before re-screwing it in? Does anyone know a particular product?
www.sbonh.org
www.sbonh.org
Depending on how your bolster is configured, you may be able to cut an access hole underneath the seat, and cut an access hole in the cockpit liner so you can thru bolt it. At the end of the day, I think that's your best bet. You could also use a few size bigger screw as a quick fix.
If you fill the holes in they will eventually loosen up again over time. If you're looking for a permanent fix I would figure out a way to thru-bolt it. That's how my boat is done and it's 16 years old and the bolsters are tight as the day they were installed.
Thank you.. While you are correct, there is no way for me to get to that to thru bolt. I have also heard fiberglass resin would be best? any product specifically anyone would recommend?
www.sbonh.org
www.sbonh.org
West marine sells a toggle type stainless steel bolt, it has a plastic strap on it to hold it in place while you bolt it down. Worked pretty well for an interior seat on my boat.Depending on how rough the water is you run in you may need to through bolt it, as already mentioned. I had to cut a hole next to my bolsters and put in an access plate to be able to do this on my old 12 meter. Bigger bolts just made bigger holes when they pulled out, which they always did.
What I did was pretty simple. I drilled the floor with a 3/8" drill bit and and coated a 3/8" wood dow with Gorilla Glue and inserted in the hole. Let it set up over night. Drilled a pilot hole where the screw would be reinserted, coated screw with some 4200. Screwed bolster back down. Done. Hasn't come loose since. Simple fix.
