HP500/500EFI cam grind?
The HP500 carb cam # is 169611. I can't find my old notes that had the EFI cam but it is different. Call Crane tell them the problem they will ship you a cam for about $230.00 you send them the old one. They are easy to work with.
If you are changing valve springs I would NOT recommend Crane. Try Comp Cams springs or someone else that has normal seat pressures.
I have Steps & Bubbles!
