Cooling Problem
Old 04-10-2011 | 05:08 PM
Default Cooling Problem
I have a 30' Scarab with twin 7.4 Bravos. When I went out this weekend, one motor is running at 150-155 degrees, the other is fine. I changed the thermostat, but no luck. The housing is the new stlye, cast iron, and is getting pretty nasty, but seems to be unobstructed. The engines use circulating pumps, could that be the problem? I can lay my hands on the risers, so I do not think that's the probelm, but would appreciate any advice. Thanks.
gvmv2001 is offline
Old 04-10-2011 | 05:40 PM
Too Stroked's Avatar
When was the last time you replaced the Impeller in the Raw Water Pump(s)?
Too Stroked is offline
Old 04-11-2011 | 10:40 AM
Almost 3 years ago, but I have good water flow through the exhaust.
gvmv2001 is offline
Old 04-12-2011 | 04:46 AM
offthefront's Avatar
150-155 temp is fine .....thermostat is 145* ....what temp is the other motor?
offthefront is offline
Old 04-12-2011 | 06:00 AM
Both motors have 140 degree thermostats, the other motor never goes above 140. The temp on the motor in question has been rising over the last year very slightly up to this 150-155 level. Manifolds and/or risers?
gvmv2001 is offline
Old 04-12-2011 | 07:17 AM
3 years ago? That's your problem. Impellers need to be replaced every year. More often if you are in a really dirty river or lake.
Baja 278 is offline
Old 04-12-2011 | 11:38 AM
Replace the impeller--in both engines. There is probably a vein broke off on the one with higher temp that is restricting water flow just a little.
Griff is offline
Old 04-12-2011 | 03:50 PM
Thanks! You guys convinced me. Any tricks on rebuiling the pumps, or do I just need to replace the impellers.
gvmv2001 is offline
Old 04-12-2011 | 06:22 PM
Registered User
Not sure where to get it online, but i got mine from a local guy. It comes as a kit with new bolts, impeller, gasket, and housing. The housings are plastic aand wear with the impeller! just make sure you twist the impeller in the right way. Good luck
bigblue is offline
Old 04-12-2011 | 06:46 PM
doesnt matter on the rotation ..it will flop around if you get it wrong .....lube it up good ....
