Strange Engine Noise >
Old 04-10-2011 | 07:51 PM
Default Strange Engine Noise
Hey guys,
Just started my boat today for the first time. Everything seems to be running fine but I'm getting a strange clicking sound from inside the engine compartment. It is not an enternal sound, as i used a mechanics stethascope and couldnt hear anything coming grom inside the engine itself. It seems to be coming from the very back around the drive shaft, and it sounds similar to a belt or something plastic hitting against something. I know this is very vague but any suggestions or thoughts would help.
astar77350 is offline
Old 04-10-2011 | 08:02 PM
97FASTech's Avatar
Veteran: Army
exhaust flappers?
97FASTech is offline
Old 04-10-2011 | 08:06 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Dry U-joint or bearing?
fireboatpilot is offline
Old 04-10-2011 | 08:09 PM
Originally Posted by 97FASTech
exhaust flappers?
I agree, sounds like flappers, you sure it wasnt there last year and maybe you didnt notice it?
You could try shooting a little grease in the u joint and gimbal as suggested above also, couldnt hurt
rexcramer1 is offline
Old 04-10-2011 | 08:10 PM
Coil grounding out...? Or plug wire..??? Electrical click...?
FogduckerIII is offline
Old 04-10-2011 | 08:13 PM
I fired up mine today for the first time after some work (water pumps, intakes, carbs) and 1 engine was making a ticking noise. I was instantly thinking horrible thoughts - pistons, push rods... I found that the timing guide plate had gotten pushed down and was hitting. Bent it up and back in business. I hope your noise is just as simple, but sounds like you isolated it to the azz end.
242LS is offline
Old 04-10-2011 | 09:30 PM
Internal exhaust flappers. Put your hand on the tail pipe/exhaust hose near the transom and you will feel it.
Griff is offline
Old 04-11-2011 | 06:41 AM
Thanks for all the input, what exactly are the exhuast flappers, is that what controls my captains choice exhaust? Is there a grease fitting for the u joint and gimbal? about 85% positive it wasnt there last year.
Old 04-11-2011 | 11:49 AM
There are flappers/diverters for the capt choice and there are also flappers in the exhaust tips to prevent water intrusion.
Griff is offline
Old 04-12-2011 | 07:40 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I had an internal flapper come apart on a previous boat. Rattled like hell, but was an easy fix.
I'm assuming you're on the trailer and running on a hose? Are your drive(s) "binding"? Are they trimmed all the way up?
Try switching the exhaust and playing with the trim and see if it changes anything.
Baja_342 is offline
