CRANE Ignitions
Old 04-10-2011 | 11:56 PM
Default CRANE Ignitions
Does anyone know anyone that has any Crane HI-6M Marine Ignitions or know where I can get any?? Does Crane Cams USA stock any still?
My Crane rep here in Australia tells me that they are no longer available on their system so he can't order me one in.
Does anyone have any still stocked on a dusty shelf somewhere I can try and get a hold of? Or are these things now Hens Teeth?
I am in URGENT need of a pair of them so I need to exhaust all avenues before I look to change systems bit if I am forced to, what would be the best replacements for a race application?
Ghostrider is offline
Old 04-11-2011 | 12:11 AM
cigboat1's Avatar
Try this address:WWW.cranecams.com/view.php?s_id=15 this should get you what your looking for ...... Good luck
Jim
cigboat1 is offline
Old 04-11-2011 | 01:02 AM
I do not think they are making the Hi 6M anymore. Pretty sure they quit making it when the new ownership took over.
You could use one of the other Hi 6 ignitions, but would not have the switchable timing curves and the curve would have to be built into the distributor.
http://www.cranecams.com/view.php?s_id=15
Griff is offline
Old 04-11-2011 | 02:28 AM
So no one has any old stock still?
I'd do the ring around and ask but 99% of the big sellers (CP etc) are members on here so I thought it might be worth a shot, that and long distance calls with our timezone difference would confuse the heck out of me!
Old 04-11-2011 | 07:43 AM
JIMKID Motorsports's Avatar
simple switch to msd and be done with it
JIMKID Motorsports is offline
Old 04-11-2011 | 09:03 AM
And buy two backups for when they go bad....
Philm is offline
Old 04-11-2011 | 10:36 AM
Default Fixx
I spoke to the crane reps a few weeks back at a pri show in my state a few weeks back,they said it was in the makings but i also herd the same thing over a year ago..
theie were 2 in the swap section a couple weeks ago,if their still forsale??
http://www.offshoreonly.com/forums/s...n-modules.html
FIXX is offline
Old 04-11-2011 | 11:38 PM
Yeh I saw them too. Kicking myself for not grabbing them but the boat was running fine when they were up!
I'm scared to death of MSD, i've read more good than bad and I really like the built it switchable curve dial rather than the MSD set up. I suppose a reason why I might read so much bad about the MSD is because there are so many out there but I still don't trust them! We'd run HI-6Ns but the curve is regulated by the distributor instead and we'd rather avoid the stuffing around to get them matched when they were running so well before!
Old 04-11-2011 | 11:57 PM
I have a friend that is selling a used one with the coil. I think he want's $200, not sure.
Jrock is offline
Old 04-12-2011 | 08:43 AM
I need one asap thanks
johnlomant is offline
