Re-rig of older Sonic with 502s, TRS...what order? >
Old 04-11-2011 | 01:56 PM
Default Re-rig of older Sonic with 502s, TRS...what order?
Doing a re-rig of an older sonic. I have all the parts, just trying to figure what order is the most logical/easiest and any other tips.
I imagine first thing is to bolt transom assemblies...then tranny and motor? which first?
Am used to Bravo one setups, so not sure on the install procedures with a tranny and TRS...
Any help would be appreciated!
Rambocj7 is offline
Old 04-11-2011 | 03:27 PM
Not sure what model you have but there is no way I would have enough room to move the motors forward for a tranny on my setup. What model are you using?
FuelinAround is offline
Old 04-11-2011 | 03:43 PM
Transom assembly on first. Then tranny bolts to engine outside the boat and the two go in as one unit. Then drive goes on.
picklenjim is offline
Old 04-12-2011 | 09:58 AM
Thanks for the input!
The model is a 36SS with a stepped hull. It came with TRS and trannies at one point...cut outs are TRS.
Rambocj7 is offline
Old 04-12-2011 | 11:02 AM
Should be a breeze.
