i need old gas pumped out.........
Yup like Running Hot said. I got a small electric pump, hooked it up to my fuel tank and filled up a 5 gallon jug. Filed up my car, then my wifes car then stated to fill up cars in the parking lot. Good day for a lot of folks!
Put your best foot forward!
Even old gas will work in most lawnmowers, etc. Unless there is water or excessive gunk in it you can probably use it for something (or worst comes to worst, burn it like Audio said). You really don't want a service to come take it out. It is WAY too expensive. They wanted $80 bucks to show up, and $7.XX per gallon to take it out. My friend called them because he was worried about his old gas gunking up his carb, but the final price of taking out all of the old gas would have cost more than replacing the carb with a newly rebuilt carb.
FWIW, we ended up cutting his fuel line and temporarily installing an electric fuel pump that I had laying around. After we were done we put a fuel filter in to splice it back together.
I know someone that was in the bulk gas handling business for most of his career. They always had vast expanses of concrete around them where they worked. He told me once that when he had a small amount of gas he needed to get rid of, such as a 55 gallon drum, he would just tip the drum over on its side, let all the gas run out on the concrete, and it would evaporate & be gone in 10-20 minutes, depending on the temperature, wind, etc.
I had 40 gallons of turpentine in the Monza when I first got it. Scored a 45 gallon drum. Picked up one those super cheap pumps that run off your drill at H/D. Then called the local dump and asked about their hazardous waste days. Pumped it out and ten dropped it off. Pretty painless.
Yet, you condone burning it off, as you stated above. Go figure. Lets face it, its getting more and more difficult to process stale fuel properly, no matter where you are.
Burning it is no different than running it through your car (sans the cadillac converter). Pouring it into the ground is a huge mess that requires extensive and costly excavation to get rid of it.
