guesses on power? >
guesses on power?
guesses on power?
Old 04-18-2011 | 03:25 PM
Default guesses on power?
Hi I was wondering if anyone had a good guesstimate on power from the following combo:
588 ci (tall deck)
9.5:1 cr
269 cc merlin cast iron oval ports
741 hyd roller cam
1.7 roller rockers
Victor Jr. intake
1050 cfm dominator -- as i type this i think this will be on the big side...
I've been looking for a downloadable desktop dyno but haven't found a good one yet -- any ideas on this also?
Thanks, Dave
delsol is offline
Old 04-18-2011 | 08:15 PM
REDCHECKMATE's Avatar
REDCHECKMATE is offline
Old 04-18-2011 | 09:09 PM
I think those heads may be a bit small. 9.5:1 may be pushing it with iron heads also.
I doubt you will see 700hp without a great tune, more like 650hp.
Philm is offline
Old 04-18-2011 | 09:59 PM
Heads are too small and cam could be better. Carb is just right. 650 should be right on. 9.5 comp is good with Iron but is the highest to go. That thing will be a torgue monster though!
GTOFFSHORE is offline
Old 04-18-2011 | 10:03 PM
Rookie's Avatar
Thanks, Dave
Here, I used the flow #'s from Worlds web site and Cranes 741 cam specs.
Rookie is offline
Old 04-19-2011 | 06:58 AM
Well it looks like I was pretty close on my guess.
Philm is offline
Old 04-19-2011 | 07:01 AM
Going to have a ton of torque !
ezstriper is offline
Old 04-19-2011 | 08:07 AM
Thanks -- i was figuring 650 +, realizing heads are on the small side along with cam.
Would there be a better cam for this -- its the easiest/cheapest change -- compared to the heads --
something that will get me to the 700or even 750 hp? Or are the heads going to be the restrictor?
Rookie where do i go for one of those dyno 2000 software programs?
Dave
delsol is offline
Old 04-19-2011 | 08:34 AM
Rookie's Avatar
Dave
AutoZone 8 years ago for $39.95.
When I get home I will put in some different #'s I have for cams and heads. It has been 95% accurate on NA engines with correct information to input.
Rookie is offline
Old 04-19-2011 | 08:36 AM
thanks
delsol is offline
