Speed Calculation
Old 04-20-2011 | 11:24 AM
Default Speed Calculation
If I have a 25 pitch mirage plus prop spinning at 5600 rpm's, with a 1.5 ratio drive, about how fast would I be traveling?
rob vanharten is offline
Old 04-20-2011 | 11:30 AM
79.5 at 10% slip.
http://www.marksmarineinc.com/prop_calc.aspx
GPS your speed and you can figure what actual slip is. Be sure your tach is right on.
picklenjim is offline
Old 04-20-2011 | 11:33 AM
I am not familiar with boats that big and what kind of prop slip numbers are typical for a boat that size. Just playing around I put in 13% slip (high for the boats im used to) and it comes back to 88mph
calculator:
http://www.mercuryracing.com/propell...calculator.php
edit: actually after pickle posted his numbers i started looking into it. the merc numbers are way off of other calculators. this is the site i normally use http://www.rbbi.com/folders/prop/propcalc.htm and it seems to be more accurate at 76.9mph with 13% slip
hawk232 is offline
Old 04-20-2011 | 11:36 AM
I think you left the slip field blank hawk.
Old 04-20-2011 | 11:39 AM
CigDaze's Avatar
25 / 12 (inches/feet) / 5280 (feet/mile) * 60 (minutes/hour) * 5600 (revs/minute) / 1.5 (engine revs/prop revs) * 0.90 (efficiency(1.00 - 10% prop slip)) = 79.5mph.
Or more simply:
(Pitch * RPMS * Efficiency) / (Ratio * 1056)
CigDaze is offline
no i entered .13 for slip, i wonder if the merc calculator cant work backwards like that. at any rate i updated my post with info from the site i normally use!
hawk232 is offline
Old 04-20-2011 | 11:42 AM
CigDaze's Avatar
It works fine. You have to also enter your prop slip guess, otherwise it assumes 0% slip.
CigDaze is offline
Old 04-20-2011 | 11:48 AM
Thanks, picking up boat Saturday with the new power. Was really hoping for upper 70's to 80mph. I think I will be flurting with that 80mph mark!
Old 04-20-2011 | 12:43 PM
glassdave's Avatar
Neno the mind boggler
I got a pretty cool prop calculator app for my Droid from Orange Dreams, works great. What are some general rules of thumb for a slip ratio?
08 OPA High Points Champion
glassdave is offline
Old 04-20-2011 | 12:56 PM
CigDaze's Avatar
On my heavy, Old School V-bottom I see 13-14%
CigDaze is offline
