500HP how can you tell it is a real one vs. a 454 painted blue?
There should be a large 8.2 cast in the side of the block. Also I am pretty sure all HP500's came with roller rockers on studs so If you have those that is a good start.
Look for the 8.2 stamped on the block, in the freeze plug area. Merc also made a HP450, that was a 454, but almost identical to a HP500 spec wise, other than the Cubic inch.
Even if it says 8.2 on the block, it will be a 502, but can have anything inside it as far as crank, rods, pistons, cam, etc. Tearing it down is really the only way to know anything for sure.
