Boat radio circuit amperage >
Old 04-26-2011 | 01:31 PM
Knot 4 Me's Avatar
Default Boat radio circuit amperage
For those that know off the top of your head, how many amp circuit was your boat's radio on from the factory? TIA!
Knot 4 Me is offline
Old 04-26-2011 | 03:24 PM
I think mine is on a 10A breaker.
hotjava66 is offline
Old 04-26-2011 | 03:50 PM
I have a 20 amp breaker on my head unit and separate breakers and relays for everything else.
Baja 278 is offline
Old 04-26-2011 | 04:18 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Have an JVC HU right in front of me. It has a 10A use on the back. Just reordered a different JVC HU, that one has a 15A fuse. No idea why the difference as they both are same specs.
US1 Fountain is offline
Old 04-27-2011 | 09:34 AM
Knot 4 Me's Avatar
Thanks. Was going to order something and it stated the head unit had to be on a 15A circuit. Can't get to the boat until this weekend so was curious what most are set up on.
Old 04-28-2011 | 12:34 PM
I don't think I've ever seen a HU that would actually draw 15 amps but you should be good to go anyway since most builders use 15 or 20 amp circuits.
mlb75 is offline
Old 04-28-2011 | 12:48 PM
Knot 4 Me's Avatar
The head unit is not the draw I'm concerened with. I was going to try the Alpine Power Pack which raises the RMS rating from 18W X 4 to 45W X 4. Gets pretty good reviews for the most part but requires the stereo's existing circuit to be 15A or you have to run a separate power/ground wire. If you are going to do that you might as well run a "real" amp. This plugs and plays behind the head unit with no additional wiring needed as long as the existing circuit is 15A or greater.
