Flywheel/crankshaft spacer for Steel motor mounts?
Am currently re-rigging my boat with a pair of 502 motors that originally came in a cruiser with trannies. I have everything needed to put them in my Sonic 36 ss.
The difference is that in the sonic with a TRS setup I have steel plates that mount to the stringers. One goes under the motor and the 2nd bolts behind the flywheel.
The 2nd mount effectively moves everything back by about 1/4inch and I have very little starter engagement now and the dowel pins that align bellhousing are barely long enough.
Do they make spacers for the motors that could space out the flywheel the extra 1/4 inch I need?
Let me know
Let me know
So your saying you have a TRS setup in the sonic. If so then why do you need the the rear plate mount. Doesn't the trans tailstock mount into the transom plate. What trannies you going to be running in the sonic?
http://www.offshoreonly.com/forums/g...ing-ssm-v.html
Am running what looks like stock Velvet transmissions with tail stock mounts. I guess it would meant I have essentially 3 mounts...and that doesnt make sense eh?
I just saw the plates in the hull and assumed I needed 2 run both the steel mounts. The engine compartment is bare now. Have the trannies and TRS gimbal assemblies and they came with these mounts.
Does it make sense to just use the front steel plate and use the tail stock mounts on trannies to the TRS inner plate?
Yep. That's all ya need. TRS don't use a rear plate set up like that. Them B-W's will mount right on the transom plate. Actually don't need the plate on the front either though I quess you could use it if it is set up correct. They normaly just use motor mounts like these.
http://www.perfprotech.com/store/ass...),978-220.aspx
The stringers arent setup for that style mount, how do I set it up for that? Just drill holes or make some sort of base plate on the stringer?
My engine mounts look similar to this:
http://www.offshoreonly.com/forums/a...ore-mounts.jpg
My engine bay looks like this with 2 mounts ready for the 2 steel motor mounts:
http://www.offshoreonly.com/forums/a...untain-021.jpg
So are you converting this boat to TRS drives? What was in it originally?
If the boat is already set up to use the plate on the front that may be the way to go. You would have to figure out exactly where the mounts needed to be and then either screw them into the stringers or make base plates, whatever need be. Mine are on steel base plates which sandwich the stringers and are raised about 3 inches higher than the stringer. Just all depends on the boat and how high the gimble assemblies are in the transom.
I may have to do the sandwich style as you say, I realize I have those plates as well. I dont know much history about the boat, just picke it up last weekend. It has been without motors for a solid 12 yrs. Used to be a race boat for Sonic. I thought it was a TRS setup, but could have been something else...the rear holes definitely look like TRS.
I may just go with tranny mounts and use the traditional mounts in the front that sandwich the stringer....
Let me know
Let me know
Yeah, the motors were out of a cruiser some MPI 502 Blue Water motors.
So youre saying I should use the 3 mounts as opposed to just using front mount and the tail shaft mount? I think this boat had some blower motors at one point which is why its set up like this.
I do know a machine shop in the area. So I should still use the rear mount and machine the bellhousing down a 1/4? What about the input shaft on the tranny, will it be long enough? Am assuming yes, but this setup is new to me...
So your saying I should use the 3 mounts as opposed to just using front mount and the tail shaft mount? I think this boat had some blower motors at one point which is why its set up like this.
