IMCO single hydraulic steering arm
This may sound funny, but is there any way to "tighten" the steering tension on the single arm hydraulic to make it "harder" to turn the wheel? I like mine to be somewhat tight and this one is very easy to turn.
thanx
thanx
A full system has hydraulic lines going to a helm unit behind the dash.
An add-on system ties the external ram into the merc steering unit on the transom assembly. From there, there is a steering cable that goes to the helm.
Based on the symptom you described above, It sounds like you have an add-on system.
