Interior cleaning products?? >
Old 04-29-2011 | 01:54 PM
Default Interior cleaning products??
I have a white interior on my Warlock and in doing a spring cleaning I am finding a couple of black spots that I think are mold. I have tried simple green with little results. Someone recomended using magic earasers, I am worried about this product due to it having bleach in it and may bleed the blue out of my cover. What product would you guys rec??
hemi2001 is offline
Old 04-29-2011 | 03:06 PM
http://www.westmarine.com/1/1/18225-...n-remover.html
Then follow up with this:
http://www.303products.com/shop303/i...protectant.cfm
87MagnumII is offline
Old 04-29-2011 | 03:15 PM
just went thrue same thing,,I found a product at Walt Mart at the marine section called mold and mildew cleaner/remover,,made by seasence,,it works great and same on stitching...not all Walt marts carry it so check with your local store,you might need to order on line.
boatnt is offline
Old 04-29-2011 | 08:29 PM
rgrgoog's Avatar
I use TILEX (bathroom/shower cleaner), followed by water and then 303 protectant. It works good for me.
rgrgoog is offline
Old 04-30-2011 | 11:34 AM
Mr Clean "magic erasor" works GREAT!
wtfo is offline
Old 04-30-2011 | 12:05 PM
GoJo or Simple Oarnge hand cleaner and a terry cloth rag!
The stuff with the grit will even pull most grease stains.
KWright is offline
Old 04-30-2011 | 03:28 PM
I mix a little clorox with water into a spray bottle. Then I use Meguire's leather/viynl renewer. Works great on my white interior.
Got Cigs is offline
Old 05-01-2011 | 08:40 AM
When there is a specifically designed product for your marine interior cleaning, why is the heck are some of you still using off the shelf general cleaners? Great way to destroy that nice interior material. For what? To save a few pennies?
Com'on. Spend a few minutes and call Dennis (he is the owner and a chemist). He can explain in detail why you should be NOT using many of those "off the shelf" products.
I have used his cleaner and it really works.
ROTAX454 is offline
Old 05-01-2011 | 09:01 AM
Could you share the info on the company and the product?
RaggedEdge is offline
Old 05-01-2011 | 09:39 AM
sorry guys. Here is the link. Dennis is very active within the performance marine industry. He attends and supports many poker runs throughout the year.
http://www.biokleen.com/marine-vinyl-cleaner
ROTAX454 is offline
