warning alarm >
warning alarm
warning alarm
Old 04-29-2011 | 07:14 PM
Default warning alarm
I have a 2000 502 mag mpi the engine warning alarm is going off the code i am getting is general warning # 2 telltale indicator can anyone tell me what this is i tryed changing the oil sending unit that works with the alarm no luck cleared code and it keeps coming back motor is not running hot has 40 psi oil pres. any help would be great thanks
33-outlaw is offline
Old 04-29-2011 | 08:47 PM
It's been awhile now, But from what I can remember either general warning #1 or 2 is tied into the stern drive oil reservoir bottle and I believe the other number is tied into the "transmission" oil level or heat on a MIE (Inboard Engine).
http://www.boatfix.com/merc/Bullet/99/99_03.pdf
Found by Dave first.
http://www.offshoreonly.com/forums/g...evel-lamp.html
Good luck.
Last edited by lakematdude; 04-29-2011 at 10:38 PM. Reason: I was able to confirm my memory for you, lol.
lakematdude is offline
Old 04-30-2011 | 02:09 AM
The alarm only goes off for low oil pressure, high water temp or low drive fluid. Its either a bad sender or its in the wiring.
Griff is offline
Old 04-30-2011 | 04:55 AM
thanks i will look farther into the wiring and senders tryed changing over drive oil senders ,water temp sender boati is running at 40 psi and 162 temp on the scanner
Old 04-30-2011 | 08:34 AM
All the senders complete their circuit to the alarm system by closing to ground. Remove each one individually with the engine running at temperature and alarming, see which on stops the alarm. There is an oil pressure and water temperature sender for both the alarm and the guage, be sure you are pulling the correct wire. If the guage goes to zero you have the wrong one. The drive resovoir bottle has a float in it that is common for sticking down at the bottom and alarming. Good luck
Boat1 is offline
