Nickel-Plated Aluminum
Old 05-02-2011 | 08:53 PM
Default Nickel-Plated Aluminum Fittings and salt water?
Has anybody plumbed salt water through a Nickel-Plated Aluminum fitting? I'm interested in the longevity of this fitting in a salt water application.
Here is a link to a fitting im interested in made by Aeroquip:
http://www.aeroquip.cc/fce1534-fbe1534.aspx
Thanks for any and all input....
Tom
duramaxtommy is offline
Old 05-02-2011 | 09:10 PM
I would say stainless in saltwater, salt will ruin stainless over time make sure to flush often might last
firehawkcat is offline
Old 05-02-2011 | 09:24 PM
Boat only gets used on the weekends and gets flushed religiously every time its used. I would gladly use stainless, if a fitting like this was made out of stainless. I'm only considering it because of mounting restrictions and interference of other plumbing. but if someone knows of a manufacturer that makes a fitting like this out of stainless id be very interested!
Old 05-03-2011 | 08:07 PM
Don't use them, I had a set that I used on the stainless braided lines for the external hydraulic steering rams. They lasted a month using them in saltwater and that was only two days a week and washed after every use. When mine went it was the beginning of the 4th of July weekend, fired up the boat checked to see if I water pumping through the engine and noticed a rain bow trail film on top of the water.
dicdik is offline
Old 05-03-2011 | 10:02 PM
fireboatpilot's Avatar
RIPSTA Racing Team
even with the best flushing the aluminum fittings wil corrode. S/S for salt water.
fireboatpilot is offline
