1979 pantera 24 Imron paint job pics
Talked with a few of you over the past two years while I was repainting my pantera 24. After sanding the base clear down to the factory gel I primed the hull with U-TECH E350 epoxy primer. It's high build and sandable. After a ton of body work and block sanding I shot it in paper white Imron. Put the last two coats on soaking wet. It looks great! Here is a link to the photobucket link where I posted some pics. I plan on posting all the photos tomorrow.
http://s891.photobucket.com/albums/ac116/buck30/
Nice job, Sounds like we took similar paths. I have a 78 Spectra 32' that I did and am doing a lot of deck mods to and also going to be ready for paint soon. I've painted cars for years and a few boats however never used imron. I was told it can be difficult to spray and even more difficult to sand out after. Just doesn't lay out like your typical bc/cc or single stage systems. I would really like to use it for the hull sides and deck. Looking for a canary yellow or something simular. I am close to having the glass work done however it's obvious I don't do glass work for a living so will need a good strong durable filler. Overall I have it pretty straight. Been extremely fussy. What did you use? Plan on the same primer. Not sure if you got into much glass work for filler or not. Let me know when you can. I'll have to post some pics soon so you can see what I'm up against. About sick of itching and sticking to the pillow at night though. lol.. I actually enjoy the work. It's fun and rewarding as well.
Thanks,
John
PS I will find an old thread of my project and send it to you so you can see what I'm up against. I pulled it out of the shop yesterday for the first time after doing the mods and it's taking shape. Hard to see in the stall I do the work in.
John
Thanks,
John
John
Thanks,
John
John
Thanks,
John
John
I sure know what you are talking about! They are a ton of work. the imron I put on it was reduced 25%. Without the reducer it would look like total crap! It was not easy in any way. The u-tech e350 epoxy primer worked wonders. It goes on heavy and is sandable. Unlike all other epoxy. I took the time and set up my garage so that I could move all the way around the boat while painting it. the last two coats went on super wet. It's so nice now I don't even plan on buffing it. Thanks to everyone that has commented on her. I'm working on all my other parts now so I can paint them all with black imron. More pics to come.
Thanks,
John
08 OPA High Points Champion
