Can any of you Cafe or Top Gun guys help me out >
Old 05-04-2011 | 06:49 AM
seafordguy's Avatar
Default Can any of you Cafe or Top Gun guys help me out
I need to know what size batteries I need. I hate to guess and then have them not fit when I get home.
I'm out of town, but want to buy them on the way home friday without going all the way to my house to measure and then all the way back out.
Thanks,
Eric
seafordguy is offline
Old 05-04-2011 | 07:24 AM
BillR's Avatar
OSO Moderator
U probably have group 27 batteries. The cig battery box will fit up to a group 31.
Try to get 800 amp cc / 1000 mca starting batteries. If you go with a flooded battery, interstate makes a decent marine starting battery (27M-Xhd) . If you want the best, get an Odyssey agm battery (31M- PC2150), but be ready to spend $300+ per side.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-04-2011 | 07:41 AM
cigrocket's Avatar
My 1993 Top Gun has 31 series Batteries in the boat. Hope this helps!
Kind of see one in the lower left corner
Attached Thumbnails Can any of you Cafe or Top Gun guys help me out-img_0004.jpg
cigrocket is offline
Old 05-04-2011 | 07:55 AM
CigDaze's Avatar
I have group 31's in my Cafe.
CigDaze is offline
Old 05-04-2011 | 08:25 AM
seafordguy's Avatar
I was hoping to go with the Interstate Marine batteries. I know they are pretty cheap at Sam's Club. Unfortunately I don't see myself using the boat enough in the next year to warrant the expense on the AGM's.
Great - I appreciate it.
Thanks CigDaze!
Since I am mostly concerned about being able to run the stereo for long periods of time should I be looking at Deep Cycle batteries with less CCA but more Staying Power??
Old 05-04-2011 | 08:28 AM
CigDaze's Avatar
You got it. If you want to run equipment off your batteries for extended periods of time then deep cycles are what you're looking for.
Both of mine are deep cycles and I've never had a problem cranking ever, and yet I can enjoy music all day while sitting at the sandbar using only one battery and keeping the other in reserve.
CigDaze is offline
Old 05-04-2011 | 08:38 AM
BillR's Avatar
OSO Moderator
Yes
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-04-2011 | 08:59 AM
seafordguy's Avatar
10-4 - I wasn't as worried about the Cranking Amps for a couple reasons - one is I only use the boat when it is hot out (less cranking power required), and two the Parallel start switch is easily used if there is an issue.
Old 05-04-2011 | 09:10 AM
Nice engine compartment!!!
kreed is offline
Old 05-04-2011 | 09:48 AM
cigrocket's Avatar
Thanks for the compliment. I need a new battery, I think a plate broke in mine. Won't charge. I am going to replace it.
