Mercruiser 575 SCI info wanted
Registered User
I am looking at a boat that has a pair of 2001 Mercruiser 575 SCI's and would like to know how some of you like them. Things to look for or look out for. The engines and boat have 174 hours and look like new, boat is a 30' Hallett. Also has electronic shifting. The control works a box in the engine compartment that has all of the cables going to it.
Also what kind of fuel burn at a moderate cruise like 3000 rpm.
Thanks in advance.
David
Thanks in advance.
David
I'd guess fuel consumption 30gpm at 3000rpm
While looking at boats to purchase that had these powerplants I did some asking around and came up with the info that they're great motors but replacement parts are expensive and not as commonplace as most while searching for them.
At those low hours if the boat really appeals to you I'd say "jump on it". They're sure to have plenty of life left in them prior to any major reconditioning.
I'm one of the optimists that thinks the economy is truly rebounding and the low prices for boats of this caliber will soon rise again.
Just bear in mind that all my info comes from one performance boating buddy and all my internet searches for answers.
See ya,
Kelly
Registered User
My info is direct from a newbie into high performance boating so it should be considered half ass at best.
See ya,
Kelly
See ya,
Kelly
thanks,
David
For 2001 motors, the headgaskets should be upgraded ASAP if they have not been already.
Those would have the older style blowers with oil bath rear rotor bearings, preferred over the newer sealed greased bearings style.
I had a set of 03's, loved them but they do like their fuel. Also some great options to make big power with that motor as a base.
On the brighter side, If U choose this boat & want a 575 Merc service manual in like new condition, get in touch!!! it sez # 8 service manual, serial # 0L601000 & above! Good luck!
I had really good luck with mine. '02's in a TopGun. Definitely time for head gaskets and probably a valve job while you're in there. Blowers might need refresh. If in salt water the thermostat housings are a problem. They do like fuel. Should rock in a 30'.
