Changeing Thermostat on 2.5
Mercman,
Yes on the temp problem. one motor runs hotter than the other. Not comfortable with it running that warm so I'm considering changeing the T-stat and the impeller that should cover my bases.
The motors are 1996 2.5/ 200 hp carb not Efi. stock motors with bobs machine nosecones. I ordered new t-stats and looked at the old ones cleaned them up a bit the motor still runs a little to warm for my likeing so I'm going to change them out and also the Impeller. But that is not a big problem. My big problem is I hit somthing this weekend and bent my prop shaft so thats going in to the shop on wed. to get a new shaft put in place. Thats going to hurt the wallet!!! Mercman thanks for the reply, I'll keep you informed as to how things go.
Mercman, how much for one of your prop shafts ? Are they new? Used ? Give me some facts?? Do you have one for my motor? 1996 2.5 carb motor. serial # ogo61445 let me know I might be interested. Anything to save a few Bucks!!!
