29ft Fever windshield problem. Help!!
I just bought a 2006 29ft fountain fever and the paint on the window frame is chipping away. It looks like the previous owner tried to solve the problem by spray paining over the chipped paint which actually mades it look even worse. To make matters worse the two front pieces of glass are all scratched up. I'd like to at least somehow sand and repaint the window frame and possibly replace the two front windows but I'm not quite sure how big or how expensive for a project this might be. Any suggestions?
very surprised there is not more help on this issue, there's a number of members all looking for help/advise on this
same here with 97 32' fever, windshield looks like garbage needs replacing with newer version
I have a plexiglas windshield and I am going to have it covered with white vinyl with the fountain script. I have seen this done and it looks good, kind of like a faring. As far as the metal frame windshield any good powdecoater or pAinter should be able to fix it up.
I have this problem on my 35 and I'm pretty sure it happens to all of them at some point. I just sand and touch up with paint as I find spots the bubble/blister. I use white appliance enamel spray paint that works/looks pretty good as a patch job. But I am just covering corrosion so not a long term fix.
The problem as it was explained to me as that Fountain didn't properly store the aluminum frames before they were painted so the corrosion was already in the metal. They just painted over the already corroding metal.
When it gets bad enough, I will probably look at a whole windshield replacement. I had a gorgeous stainless steel framed Taylor made on my previous Cobalt. I love it so much I would probably see if Taylor could recreate it for my 35's shorty style frame.
Big bucks I would imagine!
links to TAYLOR?
there's one showing on EBAY white framed but not sure it it will work on our 97 32' fever
looks like white solid vynl is the answer for ours, with painted cornes.. fountain logo across front... leave 3-4" of very front windshield in smoked plexi as that last hooked wind deflection lip of winshield is all you look through anyway..
hoping that werx for us
links to TAYLOR?
