WTB: Y-Pipe block off plate >
Old 05-08-2011 | 09:05 AM
Default WTB: Y-Pipe block off plate
Looking for a block off plate for a bravo 1. If anyone has one ar can point me in the right direction to buy on. Also how prone are these to leak as I am assuming it will be difficult to get to once engine is back in.
Baja_man is offline
Old 05-08-2011 | 09:31 AM
I have one it has an o ring to seal it $50 with bolts
kidapache is offline
Old 05-08-2011 | 09:57 AM
I have a Teague block off plate that does not work with the IMCO extension box. If you your are just blocking it off it will work fine.
I think it was $35 for the plate... if you are interested I will get the exact price. It was only on the lower for 10 minutes.
Attached Thumbnails WTB: Y-Pipe block off plate-img_0550.jpg
TW720HVY is offline
Old 05-08-2011 | 10:04 AM
Originally Posted by TW720HVY
I have a Teague block off plate that does not work with the IMCO extension box. .
Why wouldn't it work with an IMCO box? I have a Stellings box, would it affect it?
Baja_man is offline
Old 05-08-2011 | 10:24 AM
I do not know... I told them what I was going to use it with and they said it would work.
It is too wide for the key hole which prevented the gimble housing mounting. The bottom was just a little too wide. I am sure if I grind it it'll fit but I really don't want to.
I don't know if Stelling would know the answer, I would say call Teague, but they did not have the correct answer for me.... unless they make two different plates.
TW720HVY is offline
Old 05-08-2011 | 10:27 AM
Basically I have the worst luck when it come to crap like this.
I am sure this will fit perfectly on the next IMCO box produced.
TW720HVY is offline
Old 05-08-2011 | 10:29 AM
Send me your paypal info and I'll take.....only thing I can do is try it.
Good luck with rest of the project.
Baja_man is offline
Old 05-08-2011 | 10:55 AM
I have 2 with bolts,let me know if you still need one
boatnt is offline
Old 05-08-2011 | 11:03 AM
PM sent
TW720HVY is offline
